B18CR VS B18CR With B20 Vtec Bottom End
Which do you think would be pushing more horsepower and torque?
B18C (Type R) ;)
* VTEC
* Found in:
o JDM Honda Integra Type R
+ Power: 205 hp (153 kW) @ 8500 rpm
+ Rev-limit: 8,900 rpm
+ VTEC engagement@5,800 rpm
+ 137 ft·lbf (186 N·m) @ 4200 rpm
+ Transmission Type: 5-speed standard with LSD
+ Displacement: 1,797 cc (109.7 cu in)
+ Compression:y 11:0:1
+ Bore: 81 mm (3.189 in)
+ Stroke: 87.2 mm (3.433 in)
+ Rod Length: 137.9 mm (5.429 in)
+ Rod/Stroke Ratio: 1.58
+ Transmission: J4D (96specR w/ LSD)N3E (98specR w/LSD)
http://en.wikipedia.org/wiki/Honda_B_engine
B18C (Type R) ;)
* VTEC
* Found in:
or the k20 for that matter(with k24 bottom)
