- Sat Jun 23, 2012 12:36 am
#309117
so im thinking about doing a manual conversion and i have no clue what all ima need so could someone inform me on what ima need besides the manual tranmission and the manual tranny ecu thing
- Sat Jun 23, 2012 1:00 am
#309120
You will need this list at least:
pedal set from a manual 92-00 civic or 94-01 Integra
Shift Linkage
Shifter either civic or teg will work teg has a short throw or aftermarket
ECU
Clutch Master Cylinder
Clutch Slave Cylinder
Clutch line either hard line factory or aftermarket tucked line
Clutch and Flywheel
Passenger side transmission mount ( they are different)
The trans torque mount and bracket that bolts to the trans.
That should be the main parts you will need to locate. There is going to be a lot of extra wiring so a lot of the guys like to get to hunt down an manual engine harness and front end chassis harness to eliminate all the extra connectors and what not.
