biretsu89 wrote:now if im driving my car... will that bearing make a noise? or no?... if i can fix it easily... then alright... but i dont want to rebuild my tranny if its something with the gears O.o...
INSTALL THE MAIN SHAFT BEARING
Okay So now that we have tested the "Main Shaft Bearing" and bought a new one we need to take out the old one. Its very similar to taking out your Differential
1) Flip your Transmission over from the side you tested it on. so its now on the Bell housing side.
2) Take a long flat bladed screw driver and hammer and punch out the old bearing.
3) Keep old bearing in New Item's bag, hang on wall and use as a conversational piece. (Joking, However I did it >_>)
4) Flip Transmission over again so bell housing is down.
5) Put the bearing over the old hole, then either hit the sides with a hammer (what I did) or use a large socket and knock it in.
Congratulations. You most likely fixed your dieing Transmission noise.
- http://civic-eg.com/viewtopic.php?t=2775
The Bearing will make a Noise when Driving yes, Once you put in a new one the Noise SHOULD Go away.
