Page 1 of 3
need help asap. Im pissed wheels arent spinning trans is on
PostPosted: Mon Sep 21, 2009 1:35 am
by PandaHatch
just put finished putting tranny in and the wheels will not spin. I can shift from 1st to fifth with no grinds and not have the clutch pushed in. it does grind like it should when attempting reverse with no clutch. obviously goes in gear with clutch but no power to the wheels. I NEED HELP. im so frustrated it was a bitch to get the old one out and I just dont know what to do. or look for. any suggestions
PostPosted: Mon Sep 21, 2009 1:48 am
by asianrob
axles all the way in?
PostPosted: Mon Sep 21, 2009 1:57 am
by thirdson
Check for axles, CV, and maybe see if the axles connected properly to the hub
PostPosted: Mon Sep 21, 2009 2:02 am
by PandaHatch
I think you all hit it right on the head. mI was having a little trouble getting the axle in on the drivers side. is stuck out just a bit like it could go in some more but I figured once I sat the car down the weight would push it in, I never got that far it slipped my mind. anyways what the reasoning behind that just out of curiousity and what is a better way to get that axle in. i put some grease on the splines... does that still explain the no grind with clutch out issue...
PostPosted: Mon Sep 21, 2009 2:04 am
by PandaHatch
thanks for the quick replies too guys. im so heated right now I could explode but that reassures me I dont have to pull trans out again. (4th time..clutches bad trans etc.) :thumb: :thumb: :thumb:
PostPosted: Mon Sep 21, 2009 2:06 am
http://www.hondaautomotiveparts.com/aut ... CH+RELEASE
Is the clutch fork (#4 in pic) installed properly?
I ALMOST put a tranny back in a car without remembering that part one time... :oops:
PostPosted: Mon Sep 21, 2009 2:12 am
by PandaHatch
Im pretty sure it is. the throwout bearing connects to the fork by sliding behind it and over the mainshaft. The slave cylinder pushes it and it does retract so I assume its right.
PostPosted: Mon Sep 21, 2009 3:03 am
by Greasedmonkey
this is a random shot in the dark, and I truly hope its not this. But, if the axles are in and the forks there, and its still not moving, you could have some bad teeth on a gear, final maybe? or missing the gear out right. No final drive means no go.
PostPosted: Mon Sep 21, 2009 3:05 am
by PandaHatch
no final drive means Im going to beat this guys head in with a wrench for selling me a fucked tranny.I had them write out a 30 day warranty so Im trying to figure it out asap. I hope it not that too!
PostPosted: Mon Sep 21, 2009 3:06 am
by asianrob
Greasedmonkey wrote:this is a random shot in the dark, and I truly hope its not this. But, if the axles are in and the forks there, and its still not moving, you could have some bad teeth on a gear, final maybe? or missing the gear out right. No final drive means no go.
or the splines on the axle is stripped?
PostPosted: Mon Sep 21, 2009 3:11 am
by PandaHatch
no I got a look at those because I greased them. what about the shift thing with no clutch... No grinds
PostPosted: Mon Sep 21, 2009 3:15 am
by Greasedmonkey
its normal if the car is off. if its the car is running and you can do that then take the tranny off again and make sure shits on right and there in general.
PostPosted: Mon Sep 21, 2009 3:16 am
by That One Dude
How about trying to adjust the clutch pedal? I know it's remedial shit, but I battled my clutch for a month and removed/disassembled/reassembled/replaced everything three times before adjusting my clutch pedal 1/4".
Reverse is going to grind without the clutch disengaged because it's a straight cut gear.
PostPosted: Mon Sep 21, 2009 3:20 am
by PandaHatch
possible..I suppose it was messed with last time I put my clutch in with old trans. my friend didi it so I dont exactly know how to do it and he is in boot camp for army so I cant get a hold of him. anything about no grind issue. car running no clutch shift=no grind when I expect it to grind
PostPosted: Mon Sep 21, 2009 3:28 am
by Apexracing
take the boot off from the fork on the front of the transmission and manualy move it over and see if you can get it to engage then.
