- Sun Jan 03, 2010 11:00 am
#165481
Okay, So I haven't driven my car for about a week or two, and I get in and let it warm up for a few minutes then put it into gear and leave my driveway.
As I go to put it into second gear it pops out of first and into neutral.
So I push down clutch and put into second gear and it just revs out.
SO I try another gear, nothing, reverse, nothing.
So basically I can put the car into gear, I think. But it doesn't move.
Also while I was pushing my car back into my driveway I noticed a really thin line of fluid coming from under the car and on the ground.
Now I'm thinking it's the slave cylinder in front of the tranny, is this plausible, or what could be the issue?
Thanks.
Also the car is a 94 civic EX and also it's 0 degrees here right now if that matters.
Thanks.
Look to make sure the splines aren't stripped. Check the C-clip to see it is not damaged either. When the splines are lined up, it should pop back in.
