- Mon Jun 28, 2010 10:01 pm
#202388
my 92 lx, 250k miles. trans just started making a growling/knocking sound over the past few days. i notice it most at idle in neutral and above 3k in any gear. when i press the clutch in the noise stops at idle but continues growling/knocking if im driving even with clutch in.. i think it is a bearing but not sure which one. can any1 help?
- Tue Jun 29, 2010 12:29 am
#202394
bump, any1?
- Tue Jun 29, 2010 1:59 am
#202401
the noise that goes away when you press the clutch in sounds like the release bearing for sure. It's only about $20 and you can replace it w/o splitting the tranny in half. (it's next to the clutch)
- Tue Jun 29, 2010 2:44 am
#202406
would the release bearing go bad in 7500 miles? i replaced the clutch kit about a year ago. i installed a sachs KF702-03 kit.
- Tue Jun 29, 2010 3:15 am
#202414
Pretty sure its the main input shaft bearing.
When you push the clutch in, it dis-engages the transmission, causing the bearing to stop spinning. if dis-engaged at higher speeds you would have to wait for the transmission to slow down
When throw out bearings go out, they make noise when the clutch is pushed in.
- Tue Jun 29, 2010 3:47 am
#202418
do you mean the ball bearing on the top of the main shaft as in this pic?
- Tue Jun 29, 2010 5:03 am
#202424
i mean the bearing thats in the transmission case the main shaft goes into.
The one on the right missing ball bearings.
- Tue Jun 29, 2010 11:52 pm
#202523
so my coices are either crack open my first ever trans and replace the bearing or get another trans.. it would be cheaper to fix it i think, but less time to just swap out the trans, as it is my DD and need it back on the road..
- Wed Jun 30, 2010 3:17 am
#202556
I swapped my g/f's trans in her ek for a used jdm trans costed me 300$. and i priced out a bearing kit wasn't much cheaper. and the used trans had half the miles on it.
92civiclx wrote:so my coices are either crack open my first ever trans and replace the bearing or get another trans.. it would be cheaper to fix it i think, but less time to just swap out the trans, as it is my DD and need it back on the road..
- Wed Jun 30, 2010 3:19 am
#202557
i found a used trans with 160k for $80
- Fri Jul 02, 2010 4:59 am
#202915
ok i put a differnt trans in today and i am stuck on getting the axle to go in. any ideas on how to get it in? and i was gonna run with syncromesh fluid, if i do, do i use just that, mix it or just use 10w40 instead?
