- Thu Oct 06, 2011 7:09 pm
#276527
I´m having problems in changing gear in my eg6 (with B16 A engine), i had to push yery hard in the pedal so they gears run smothly (it wasn´t like this). The clutch master cylinder makes a sliding noise as if the rubber retainers were dry.
I had my clutch changed and i think since then it takes more strengt to make the pedal go down.
I thought the problem was with the master cylinder so i put a new set of retainers, it seemed better at first but now is the same and with that sliding noise.
it`s hard to drive like this because my knee starting to hurt and i fear to damage de gear box.
My mecanic says the gear box as a problem but it is not logical because when i start the car it all goes fine until a while when the sound came and the gears don´nt run so well
could some one help me? i don´nt know what to do. Thanks
