tranny is acting up out of no where ..
PostPosted: Tue Nov 01, 2011 8:48 pm
by Godspeed_eg8
woke up this mornign and igo to work and all of a sudden i cant change gears and i foreced it into 1st gear at a stop and after like a long min of playing with it i finally got it in ( haha ) and it was the same for everyother gear.. but heres the other part when i put it in reverse all you hear is grinding until its in but just even putting it close to reverse its strts to grind what could be happening ?!
PostPosted: Tue Nov 01, 2011 10:14 pm
by Fada Blayne
u check ur reservoir? you might be low on fluid. do that and report back
PostPosted: Tue Nov 01, 2011 10:38 pm
by poorman type-r
Do not drive your car if you are low on fluid. I broke fifth gear in a b16 by forcing it into 5th and keeping it in gear when it wanted to pop out.
PostPosted: Tue Nov 01, 2011 10:47 pm
by Godspeed_eg8
Fada Blayne wrote:u check ur reservoir? you might be low on fluid. do that and report back
if your talking about the bolt that you can drain out the fluid , then i did check that and its leaking abit but i undid it and its got fluid in it
PostPosted: Tue Nov 01, 2011 11:07 pm
by Fada Blayne
check the reservoir by the brake fluid
PostPosted: Wed Nov 02, 2011 1:19 am
by Godspeed_eg8
Yup I did and it was low so I topped it oFf after I bled it and I also checked is the slave cylinder and there was fluid in the boot so I'm guessing it leaking from the seals do you think it could be that ?
PostPosted: Wed Nov 02, 2011 4:03 am
Yeah if there's fluid in the boot, replace the slave cylinder :thumb:
PostPosted: Thu Nov 03, 2011 7:36 pm
by Godspeed_eg8
ok so i replaced it but now its a bit better and its better in 3rd , 4th and 5th but 1st and 2nd and reverse is shit kaka i took it to a local shop and they told me it could be the linkage or the master cylinder and he said if that wasnt the problem maybe if i put something to put the slave cylinder pin a bit more that could also help .. any idea guys ?
PostPosted: Sat Nov 05, 2011 10:33 pm
by Godspeed_eg8
anything anyone? :(
PostPosted: Thu Nov 17, 2011 2:06 am
by Eg6H2D
Godspeed_eg8 wrote:ok so i replaced it but now its a bit better and its better in 3rd , 4th and 5th but 1st and 2nd and reverse is shit kaka i took it to a local shop and they told me it could be the linkage or the master cylinder and he said if that wasnt the problem maybe if i put something to put the slave cylinder pin a bit more that could also help .. any idea guys ?
If your slave pin isnt being pusshed out far enough as it should. then your line does not have enough pressure and u need to repolace your CLUTCH MASTER CYLINDER.. :thumb:
PostPosted: Thu Nov 17, 2011 3:23 am
Or you could have some air in the line. Does the pedal feel 100%?
