Doing a Tranny swap Auto -> Manual
Hey guys, I'm planning to be converting a D15b7 auto to a manual using a D15b2 box [as I have a D15b2 manual donor car]
Now I understand most of the parts for the swap I will have from the donor car with the B2 box, but my main concern is the Auto to manual mount - Does this mean th chassis of the autos are slightly different or will the manual mount from the donor work, as well as the lower front torque mount?
I've searched and found this list of parts I'll need, I assumed the parts I've ticked I have with the conversion [I've not yet disassembled the donor car]
✓ Manual transmission from a 92-00 Civic
✓ Manual Starter from 92-00 Civic
✓ Clutch assembly
✓ Flywheel and Pilot Bearing
✓ Manual Flywheel bolts (longer than auto)
✓ Master Cylinder from a 92-95 Civic
✓ Slave Cylinder from 92-00 Civic
✓ Clutch Line (OEM hardline or Earl's braided stainless)
- Auto to Manual Conversion Passenger motor mount
- Manual lower front Torque Mount (mounts to transmission)
✓ Manual Rear mount from 92-95 Civic (auto rear bracket is the same as manual)
✓ Shifter & Shift Linkage from 92-95 (96-00?) Civic
- Bitch pin & linkage hardware
✓ Manual throttle cable (92-95)
✓ 1.9 Qt Manual Tranny Fluid
✓ Manual ECU
Now my other question - Is the bitchpin and both mounts able to be swapped over from my Hatch donor?
And If anyone can offer any tips and what not for doing the swap I'd greatly appreciate it. When I do the swap I'll try and do a DIY of it.
✓ Clutch assembly
✓ Manual ECU
