b shift link
PostPosted: Fri Jun 22, 2012 8:27 pm
by reaperstk
alright its gonna b a stupid question so bare with me here, i hav a 92 eg hatch with ls swap and a gsr tranny wid lsd, now the shifter points a little to the left cuz it was customized due to auto - manual swap, real question is when u guys r on nuetral and just wiggling left n right, can you hear your shiftlinkage touching or tapping on eachother, mine does and im curious cuz its quite hard to down shift into third when im making a turn, im thinkin bushing, linkage, or syncros, thanks all
PostPosted: Sun Jun 24, 2012 2:01 am
by reaperstk
:hehe: thanks for the replies ya, ok i just changed out the shift link n put a ls in, my question is the old one is bigger or fatter but same legnth, anyone wid any ideas
PostPosted: Sun Jun 24, 2012 2:16 am
by EG Love
you had a d series linkage at first, and now you put in an ls linkage? also not sure what you mean by the linkage points a little cause it was modified. As far as i know you need a b series linkage with a b series transmission and it should bolt right in
PostPosted: Sun Jun 24, 2012 2:41 am
by reaperstk
yes both bolts right in just that idiot i bought it from told me it was a b series shift linkage, so d series are fatter than b series? and yea the crooked stick shift was because someone drilled holes to bolt the shifter in but did a shitty job at it. just found out when i took the old one out, did the job over now its where its supoose to be,but to b sure d series are fatter then b series then right? cuz both look exactly the same just the ls one was slimmer
PostPosted: Sun Jun 24, 2012 3:00 am
by reaperstk
PostPosted: Sun Jun 24, 2012 3:05 am
by EG Love
i'm not sure, possibly. i didn't notice a huge difference when i changed my linkages but maybe there is. I can check tomorrow if i remember
PostPosted: Sun Jun 24, 2012 3:11 am
by reaperstk
yea datll be great, been lookin through the net difference on all b and d series but all it said was d is shorter then b series so im just ???? :eh:
PostPosted: Sun Jun 24, 2012 6:28 pm
by EG Love
From what I could tell the b series linkage i have is a little longer than the d-series linkage. The b series also has a rod that is fatter, and inside the car it sits back more towards the seats i think. I'm also having problems with my shift linkage right now though, i've got the spring pin stuck halfway in, and the linkage wont sway side to side :S
PostPosted: Sun Jun 24, 2012 6:59 pm
by reaperstk
lol wow u got a problem worse then mines, but thanks for the info, both of mines are the same legnth just thicker/slimmer, hope u get that problem fix tho
PostPosted: Mon Aug 20, 2012 1:53 am
by Hondahatch
all you need is linkage from a DC integra, direct fit. works perf
