squeaking clutch?
PostPosted: Fri Jul 20, 2012 4:45 pm
by JDMLYFE
everytime i press the clutch down it makes a squeaking sound, the fluid is topped up. is my clutch going?
PostPosted: Fri Jul 20, 2012 5:42 pm
Can you hear the general area where it is coming from? (pedal or tranny?)
And do you mean as you press the pedal it squeaks or when you have it pressed all the way and hold it, you hear the squeak?
PostPosted: Tue Jul 24, 2012 5:58 pm
by JDMLYFE
ass im pressing it in it squeaks, not to bad and seems to go away once im driving. still bothers me tho
PostPosted: Thu Aug 30, 2012 12:16 am
by MookyStick
JDMLYFE wrote:ass im pressing it in it squeaks, not to bad and seems to go away once im driving. still bothers me tho
Mine does the same exact thing. I don't think its a big deal. Something probably just needs a shot of WD40 :D
PostPosted: Thu Aug 30, 2012 2:09 am
by JDMLYFE
It's the slave cylinder, cheap and easy fix, 2 bolts and your done
PostPosted: Wed Oct 24, 2012 3:27 am
by Clypsay
Yeah mine does the same. should I replace the master clutch cylinder while I'm at it you think?
PostPosted: Wed Oct 24, 2012 3:39 am
by TrailerTrash
JDMLYFE wrote:It's the slave cylinder, cheap and easy fix, 2 bolts and your done
more like 2 bolts, a rubber booty, clutch line fitting, put it all back together, and bleed :thumb:
it could be the slave or just in need some some WD as said above
PostPosted: Wed Oct 24, 2012 3:47 am
by 92civic_vx
mine squeeks too, i need to spray some wd every few months.
PostPosted: Fri Dec 14, 2012 8:41 pm
by JDMLYFE
where you spray the wd40 on? might as well just do that lol
PostPosted: Fri Dec 14, 2012 8:48 pm
by HeikDiesel
If you can hear the noise inside the cabin of the car it's NOT the slave. The slave is way up by the transmission. I'd check the linkage for the CMC and fix whatever is going on up there
