- Thu Apr 03, 2008 1:40 am
#48948
teal_dx wrote:KRYSTED9354 wrote:teal_dx wrote:what tranny fluid did you use?
lines are bled all the way?
any leaking from lines or the master or slave cylinder?
nope i think i used brake fluid no no someother thing it said to use in the haynes manual ! also i just saw it empty and it didnt go in at all filled it and got better just from time to time when cold or sitting for a wile it does hat also while im at it !! when i start on low rpm my car shakes is that a problem or normal ?? i mean by shake is its rough ?
u can use brake fluid for the hydraulic clutch line/ master cylinder.
You must use tranny fluid in the transmission, preferably Honda MTF you can buy at the dealership. it is good stuff but expensive.
some clutch chatter (shaking when starting to move from a stop) is normal but usually is not too bad unless you are using a 6 puck clutch (stage 3)
like if id start in 3dr it really shakes ,PS EXAMPL i dont start at 3rd , ok thanks also teal or mike can u change the thing under my name to say 160WHP AZ6 thanks
"If I see it, Then i can, If it changes, Then i will adapt. If i make mistakes, then i will learn."
