Page 1 of 2
Shifter hard to put in gear?
Sat Feb 07, 2009 5:40 am
by suspendedHatch
On my Integra sometimes the shifter doesn't want to go into 1st. If people are behind me in the intersection I end up taking off in 2nd. 3rd gear I always sort of hold it down as it takes longer to go in. Other times reverse gives me the same trouble as 1st. What causes this? It's a brand new clutch. Fresh Honda MTF...
Sat Feb 07, 2009 6:36 am
by chrono404
I have had similar issues in the cold. If it wont go into first I pull the shifter into second then back up to first and it always goes. Same thing with reverse.
Only happens when its cold outside though.
Sat Feb 07, 2009 6:56 am
by Sentry
Reverse isn't synchronized so it's normal that it's tough to engage.
Check shift linkage and hydro system.
Sat Feb 07, 2009 3:38 pm
by Gorveatt
I find it hard to go into 1st unless your almost to a complete stop, like below 10kph. but if you're stopped there shouldn't be any problems. maybe a bad syncro
Sat Feb 07, 2009 7:30 pm
My 96 hx does the same, only when it is cold out.
I don't know the cause, I'd guess there might be some tolerances that are out of spec in the transmission. Usually if I tap the gas and blip the rpm's to 1500 or so it will go right in, or I shift into 3rd first then it goes right into 1st gear.
I have 5w30 or 10w30 in that tranny, not sure if switching to Honda MTF would help or not.
Sat Feb 07, 2009 8:02 pm
by jmsplitfyre
Same here, it's hard specially if it's like -10 or lower outside.. Hard to get into reverse sometimes too.. GM synchromesh?
Sun Feb 08, 2009 4:33 am
by ohDirka
My civic did it, my crx did it and so does my Corolla. The corolla is not really exposed to cold weather but I've always just released the clutch and pushed it back in and it usually goes into gear.
Sun Feb 08, 2009 5:00 am
by hondajunkee
teal_dx wrote: I shift into 3rd first then it goes right into 1st gear.
my coupe did the same thing and i did what Brian did, any time at a stop id put it in 4th then go to first. its gotten to be a habit, i find myself still doing it in my bimmer and hatch now
Tue Feb 10, 2009 7:49 pm
by suspendedHatch
It does it consistently whether it's hot or cold.
Putting it in another gear doesn't help.
I'm going to try replacing the rear engine mount.
Sun May 02, 2010 9:15 pm
by moisesdgreat
same problem here, still trying to figure it out esp. in the 1st gear. hope somebody here finds the answer.
master and slave cylinders leaking.
Sun May 02, 2010 10:17 pm
by Yahya
i've had 2 civics and they did the same thing both, check your master and slave cylinders, (specially master, the one connected to your pedal) my civic had that greasy oil all over the place when i checked it out, i killed my gearbox by waiting to long to fix this. :\
Mon May 03, 2010 5:50 pm
by forcefedEG
suspendedHatch wrote:I'm going to try replacing the rear engine mount.
that probally wouldnt hurt either.... how are you stabilizer bushings in the linkage? im jw? it could be in your hydraulic system like satated above... i def. check the master cylinder though...
Tue May 04, 2010 12:22 am
by Eg6H2D
It sounds like the problem is in the shift fork assembly or 1st/2nd synchro sleeve. I would think this type of problem will jump out and bite you when you get the transmission open.
Tue May 04, 2010 12:41 am
by asianrob
old thread!!... but too much fluid in the trans? it could swell up gears making it hard to shift.
Tue May 04, 2010 12:54 am
by Eg6H2D
asianrob wrote:old thread!!... but too much fluid in the trans? it could swell up gears making it hard to shift.
Really? 1st ive heard of gears swelling..
