Input/Mainshaft Bearings
hey guys,
i'm going to pull my tranny out this weekend to hopefully replace the input shaft and/or mainshaft bearing because i read the DIY and have a groaning/roaring noise coming from the tranny...
question is, what else might i need in the process? all my synchros seem fine but 2nd gear is a little sloppy and no 3rd gear grind.
should i just purchase the ISB and MSB before i break open the case, i just don't want to not have the parts i need..
sorry, sounds kind of incomplete but i'm tired, thanks for the help
*EDIT
what about the throwout bearing? it makes slightly less noise when i push in the clutch at idle....
James
*EDIT
James
Reason it doesnt happen in other gears is enough pressure is built, and less stress because everything is already spinning.
