Help with windows.
PostPosted: Tue Jun 09, 2009 8:39 pm
by aznsyco
I just bought a 95 sedan and the rear passenger window does not go down. When i press the button I hear a motor noise but nothing happens/ What do i need to change? Also the rear driver window goes down very slow and doesn't want to come back up. I have to kinda push it with my hand in order for it to go up. Please Help
PostPosted: Tue Jun 09, 2009 9:21 pm
by Joplies
Have you taken the door panel off and looked at it yet? To maybe assess the situation a little better? They is alor of grease the manufacturer puts on the track and it collects dirt so you may wanna see how that stuffs holding up. The motor may be dying...Which happens sometimes
by egsedanguy
well the first thing i would do is take off the rear door panels and pull back the moisture plastic gard. then have someone hit the switch and see what is not moving. it might be off the track or its stuck. as for the slow moving one it might also be getting stuck on the slide. might need to be greased up.
PostPosted: Tue Jun 09, 2009 10:39 pm
by yashep
As the other guys said the first step should be to take the door panel out and check to see if there's broken pieces or something. Remember that our cars are 14-17 years old, and the actuators of the windows are prone to wear with time they tend to lose power for any reason. It could be any reason.
I recently put P/W and P/L on my hatchie and my driver door window works great but my pass window act up from time to time, eventho I hear noise on the motor, the window don't move.
The problem is that the plastic components that connect the motor to the regulator breaks and even when the motor is working is not actually moving the glass. I know I got to change both window regulators but they are freakin' expensive (at least out here, got quote $380 per side from Honda), maybe I'll try aftermarket and see if it works. Or buy them online if the price is right. Hope this helps. :thumb:
PostPosted: Wed Jun 10, 2009 4:14 am
by aznsyco
Thanks alot for your help guys. Ill pull out the door panel on the weekend and see whats up.
PostPosted: Thu Jun 11, 2009 6:50 am
by aznsyco
I took off my rear door panel and ripped open the plastic and tried the window again. I hear the motor buzzing abit but the window goes up really slow and after a second the motor sound stops and the window stops going up. What will i need to change or can i put some grease somewhere? If I do need to change something what will it be?
PostPosted: Thu Jun 11, 2009 7:46 pm
by aznsyco
anyone?
PostPosted: Sun Jun 14, 2009 5:10 pm
by yashep
aznsyco wrote:anyone?
If you want to try, put wd-40 in the window track to see if it frees up the window, but if you need to change anything I'll change the complete window regulator.
For the rear pass doors you'll need #2
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry2=1995&catcgry3=4DR+LX&catcgry4=KA4AT&catcgry5=REAR+DOOR+WINDOWS
:thumb:
PostPosted: Sun Jun 21, 2009 2:13 pm
by Mr Rattles
I have exactly the same problem with both my windows
opened it up and the winder is pushing the the window out of its rail and the window not been able to go up into the rubbers
have greased it and everything but ja still doesnt help :cry:
