- Sat Sep 04, 2010 8:16 pm
#212195
i read this some time ago and can't find it now...what can i do to keep the dash clock bright when the headlights are on ?
- Sun Sep 05, 2010 12:29 am
#212237
Wouldn't that just turn off the light completely? LOL
chilango41 wrote:Cut and tape off the red/black wire on the harness
You: "Dude at least you can get to point A to point B safely....."
Me: "Yeah but I wanna do it in style [;"
- Sun Sep 05, 2010 12:42 am
#212241
nope, the red/black wire is the "lights on" wire, and when clock doesnt have that wire it stays on bright all the time
RottenEg6 wrote:chilango41 wrote:Cut and tape off the red/black wire on the harness
- Mon Sep 06, 2010 9:46 am
#212461
it will trust me. i got my jdm coin pocket so i had to delete the dash light adjuster switch (cant think of the name right now lol) and to delete it i had to jump them wires and voila
Simmons wrote:This better work,ima try it soon
- Mon Sep 06, 2010 6:13 pm
#212501
yeah, you just eliminating a signal wire thats all. signal for dimming of course
- Tue Sep 07, 2010 5:15 am
#212577
yeah it worked....lol thanks!!! i'm going to modify my headlights to stay on all the time so i needed the clock to stay bright or during the day it would be hard to see
- Tue Sep 07, 2010 8:24 am
#212588
look into daytime running lights module. i remember reading my manual and it said that canadian (CDM) models came with Daytime running lights, which is a module placed i believe in the engine bay - not too sure where it connects. id rather invest into that then fuck with your existing wiring. my 2 cents.
kt95CiviCDX wrote:yeah it worked....lol thanks!!! i'm going to modify my headlights to stay on all the time so i needed the clock to stay bright or during the day it would be hard to see
- Tue Sep 07, 2010 2:09 pm
#212609
No the daytime running lamps are different then having the headlights stay on...it's a separate bulb and everything
- Wed Sep 08, 2010 1:10 am
#212682
no, city lights are a separate bulb...usually a 194 wedge
DRLs are just the low beam
as for the CDN civic DRLs there is a gray relay box under the dash on the driver side kick panel and a resistor box under the hood in the rear corner where the main wire harness goes through the firewall
kt95CiviCDX wrote:No the daytime running lamps are different then having the headlights stay on...it's a separate bulb and everything
- Wed Sep 08, 2010 4:19 am
#212712
yeah what he said
cody27 wrote:kt95CiviCDX wrote:No the daytime running lamps are different then having the headlights stay on...it's a separate bulb and everything
yeah what he said
