- Tue Mar 15, 2011 3:36 am
#243968
I know there is directions and it is pretty self explanatory but some people might need a DIY to help install their Wink mirrors. Well, here it is.
First you need to take off the screws holding your sun visors on. Here is where they are
Dont forget to take the little holders off too, when you get the screw out you need to pull the holder one way because there is a clip inside of it that you need to pop free.
After you take all screws off (there should be six between the visors and the holders) You should have some like this
Your headliner should look something along these lines
Then, you need to pop off your rear view mirror. DO NOT just pull on it, and heating it up can still crack the glass. You can use a small screwdriver or in my case a small allen key to put into the hole and slowly slide it up and off. BE CAREFUL
Then you should have your base left. If you want that off, wait for a hot day and scrap it off. THe epoxy they use is very strong. I am leaving mine on in case I ever want to put my stock mirror back on
Then you follow the instructions on the Wink mirror to set up the brackets and then put the mirror in and bolt it down. and you're all done!
Cant even really see if from the outside
I hope someone finds this helpful
Fox Tuning
'95 Civic CX with Goodies!
