- Sun Nov 11, 2012 2:20 am
#319703
someone tried to steal my eg. need to know how to replace complete ignition system.
- Sun Nov 11, 2012 1:28 pm
#319739
You are asking about the ignition system on the column yes? It will not be easy but you will have to take all the covers off and then notch the part that holds it to the column to unscrew it and then it is all just plug and play from there. I believe the dealer can just replace the key cylinder to make it a ton easier.
- Sun Nov 11, 2012 9:50 pm
#319756
if its the ignition harness that goes from the fuse box to the back of the key cylinder, that is plug and play and can be replaced. Could be found at a junk yard.
musicfien wrote:i just dont know if i have to replace the whole housing for the key cylinder or what cause they ripped out some wires.
94' civic si
JDM B16A w/AC
JDM B16A w/AC
