- Mon Sep 08, 2008 3:39 am#68779
ok camera is dead. No new pics until i can get some batteries. Tonight though I crawled up under the car and put a light up into the towers to see how much clearance I had between the upper arm and the top of the tower. I dont have much at all. I had a friend put all his weight on it to see how much it compressed, it didnt go down enough to make them hit, but Im sure its been doing it already. With that said the front is getting raised back up when I get a chance. I dont need it poking through my shock towers.
- Mon Sep 22, 2008 2:01 am#70897
when i used coilover sleeves in 1 of my 1st hatches..i lowwered them all the way down and the back sat a lil higher than the front..so i took them out and swapped the rears into the front and the front to the rear..and when they both adjusted down full the car sat low and level from front to rear ..was worth a try lol car looks good have a soft spot for teal hatches..
When a car is built to the perfection... it becomes an R¨. Keiichi Tsuchiya.
- Mon Sep 22, 2008 2:12 am#70900
The sleeves are the same. the springs are as well. The reason the back wont go down anymore is the perch were the stock spring sat. If that wasnt there it would go lower.
- Mon Sep 22, 2008 2:21 am#70904
Its getting the LS/B16a swap my other hatch has, PIC Apex Coilovers, BYS lip, Fogs from my other hatch, Apex WS2, then Paint and body work.
- Thu Sep 25, 2008 3:01 am#71416
I hope to give her some more love soon. The new ecu showed up in the mail today, and now all I am waiting for in the new header and I shall be showing you all some nice motor shots. Prepare yourselves for the shear awesomeness.
- Sat Sep 27, 2008 7:13 pm#71673
My solution to my dad breaking my O2 sensor while trying to take it out. The part with the threads is still in the stock manifold and instead of putting for effort to remove and replace just that, i got this!
