- Tue Jan 12, 2010 9:05 pm
#167946
"need an obd0 to obd1 converter"
You don't need this becouse the PM6 computer needs an 12 Ohm injectors and the injectors from d16z6 are 12 ohms ;D so no resistor box is needed
You have to get 4 wires from ecu to the engine bay (2 for the CYL sensor in the distributor, and 2 for the injectors
get the PM6 wiring harness diagram on the net and You will see how to connect the CYL sensor and the injectors
It's arpox. 5-10 minutes of work ;)
I Used a PM6 computer (OBD0) and it Works without any problems. the check engine light will on becouse the "Baro sensor" isnt plugged. Why? - becouse the 4 gen civics have external baro sensor (outside computer), but 5 gen Civic has it inside the Computer. so the PM6 ecu will display the error 13 - baro sensor. but there is nothing to worry about
SmoondaSi wrote:im likin the eg an lovin the marlin paint. i am also doing a mpfi swap but im stuck on the ecu and wiring harness. ive been told that to run a d15b7 intake i need an obd0 to obd1 converter but u havent used this... how did u get round making a 2 injector loom work with a 4 injector manifold???
also is the pm6 ecu for the d15b7?? or tha d16z6??
Peace to Poland!
