By Gunni
#306509 left my five cents on your problem links... hope it helps.
By EGCiviCKid
#306590 My b series manifold wont line up with the d series cat :?
would it be best to get a d series catback exhaust?.. or even a full aftermarket system? or can i get round this problem?
thanks :thumb:
By fatcoupe
#306685 donut gasket? :?
By EGCiviCKid
#306703 [quote]JDM b16 headers are shorter, USDM headers are the right length and you will have to twist the exhaust a tiny bit to get the b series header to mate with the SOHC cat. cai should fit.[quote]
Hummm.. ill give it a twist :)
#306710 You might have to have the flange cut off the cat and re-welded to line up with the header. I had to that once with my cat that didn't line up. Also yes a Donut gasket is what goes in between the cat and header. Hope that helps.
By Ecc0
#306730 Get a b series decat pipe this will have the flange in the right alinement.
I would suggest getting a new system as soon as so that your engine expels all exhaust fumes properly.
By Ecc0
#306881 It's the size of the exhaust pipe on a D series it's smaller than that of a standard B series though you can use the D exhaust it will never breath as well as if you get a standard B or aftermarket one.
