got some good news, and some bad news.
Good, car stayed in one piece.
Bad, got kicked out
Went 11.79@120 first pass, on wastegate only.(forgot to turn the boost controller on through hondata)
Second pass, turned on the pwm, took some timing out of first, and upt the boost in 2nd and 3rd. The one two shift I was a bit slow, but overall went well. Pwm at 60%, made 30psi in 3rd and fourth I think it was, went
10.88@138
D16z6. Golden Eagle. AFI Turbo. Precision Turbo. Hondata. CG racing.
618hp, 407tq SOHC 10.68@137
My 92 hatch SOHC build. Quest for +600hp. Check it!
It's going to be EXPENSIVE. I'm planning on building it, using chromoly. But then i need seats, harnesses, probably should do a chute, since i'm only a few MPH's away from needing that too
