By wop
#36708 i don't know why people have to comment about having a sound system, like it's not ok to have a nice ass car and a system at the same time. like you can have only one or the other. this is one of the best looking hatches i've seen. good job, man. shit is beautiful.
By sqsi
#36709 Thanks, I have spent alot of time on it to make it just the way I like it.
By JlaudioEGFreak
#80352 You did i good job on that install man do you compete usaci or iasca. You placed 1st at finals? I havent seen your car Down there before But you Said you have a jeep whats your name?. and did you use a line driver in your set up cause i cant see the w205 sounding good for a sound quality setup with only a 2v output especially with class d 4 channel amps in my opinion. But i can see you racking up a bunch of points on your install side of things which is more important regardless as far as scoring a good point sheet.
By JlaudioEGFreak
#80353 also Dynamat all facing the the same way FTW :thumb:
By sqsi
#80365
JlaudioEGFreak wrote:You did i good job on that install man do you compete usaci or iasca. You placed 1st at finals? I havent seen your car Down there before But you Said you have a jeep whats your name?. and did you use a line driver in your set up cause i cant see the w205 sounding good for a sound quality setup with only a 2v output especially with class d 4 channel amps in my opinion. But i can see you racking up a bunch of points on your install side of things which is more important regardless as far as scoring a good point sheet.
Thanks, I was competing in MECA, but with no local shows anymore I gave up on it. I am running the Alpine PXA-H701 in both cars as well, no line drivers
By CivicEG
#80484 Like the drop on it not to slamed and not to high. :thumb:
