- Mon Sep 26, 2011 7:22 am
#274502
Juice pulls 12 Second 1/4 Miles on a BONE STOCK LS engine with a 16G Turbo. Pretty sure hes around the 300hp mark and can go farther if he wants to. Check out
his thread and watch him just Destroy people on the 1320.
If your looking for cheap power get Delta Cams Its like under $120 for 2 Stage 1 Cams. Just look up what specs you want your cams to be and Delta can make them for you. They are tried and true for the American muscle cars and I know a handful of local hondas running Delta cams that are stupid fast and reliable.
That said an N/A Stage 1 or Stage 2 Cam(+ Supporting mods) will not have more power then a LS/Vtec as VTEC was made to continue the torque curve.
If you want the engine to last more then a week. Make sure you get it
PROFESSIONALLY TUNED. Why was that all in caps and bolded? Because its very important and I wanted to make sure you remember it. Dont get a Base map. No matter what anyone tells you no, its not safe for a Boosted motor to run on just a "Base Map" Base maps are meant to be a Base for getting a tune on. If your tuner says otherwise leave and go to another tuner before wasting your money.
Also, another big thing you should do before buying any parts. Look into TealDx's and Juices build thread and see what it takes to actually build a Turbo Honda. Make sure its a road you want to do before actually going down it.
Probally a Moot point, however best for future members who use the search feature. Best block to boost IMO on would be the F22b. Best flowing head honda has, Yes even better then any K Series. It has iron sleeves, have low comp for high boost, They are stupid cheap. All trannys have tall gears to boost on. Perfect for a High Boost turbo Setup. also Non-vtec cams are really really cheap from Delta. Biggest downside is tranny strength, needing h Series mounts and ruins weight distrubtion. Perfect for the 1320 though.
