CompTurboTech BallBearing Oiless turbos
PostPosted: Fri Jan 28, 2011 12:28 am
by Eg6H2D
What do yuo all think about this?
http://www.compturbo.com/spotlights/oil_less.php
PostPosted: Fri Jan 28, 2011 3:38 am
by Butterzz
Interesting but in my opinion; stick to what you know works. There's no lubricant in existance that doesn't need to be changed.
PostPosted: Fri Jan 28, 2011 4:31 am
by Ajax1989
ehh i wouldnt trust it
not only does oil lube the shaft
it absorbs heat and prolongs the life ot the turbo
if i ever run turbo imma have a water and oil cooled turbo!
PostPosted: Fri Jan 28, 2011 7:25 am
by Butterzz
Keep in mind this turbo has ceramic bearings, so it doesn't sop up the heat quite as bad. But I know what you meant.
PostPosted: Mon Jan 31, 2011 1:42 pm
by greengoblin
plus you'd have to change the grease out too probably ever so often. I like the idea of cooler oil passing through the turbo, then just relying on the ball bearing and high temp grease, to absorb some heat.
