- Tue Aug 05, 2008 11:16 pm
#64819
I'm about to do a B16a swap into my 94 EJ1. For the B16, just finished putting in JE piston's with 9.0 to 1 comp., Eagle H-Rods, and a KMS block guard. So it's safe to say it can handle at the very least 15 lbs. of boost.
I'm going to do a complete turbo set-up with a T3-T04E turbo, and have it peak at about 12 lbs. Being run with a Hondata ecu. I plan to just upgrade the stock injectors to supplement the boost.
My question is, what fuel injector size would be recommended for this set-up? My options are 440cc, 525cc, or 650cc. Is 440cc enough, better to go 525cc?
in that the case I say Funk it use the bigger ones
