chrono404 wrote:CF Hood looks good.
x2
rounDNinja wrote:overall the car looks good. not a big fan of dr-20's but you can pull them off. might i suggest going lower? 1" in the front 2" in the rear
BurqueB16 wrote:if you don't know already, you will need to get a rear sway bar reinforcement plate like a beaks or ASR to support the subframe or it could tear away under heavy turning...
Coming along really well!
slowj1 wrote:ur right u don't need it if ur runing a stock 13mm one.the only thing that sucks is that u wont feel it at all....BurqueB16 wrote:if you don't know already, you will need to get a rear sway bar reinforcement plate like a beaks or ASR to support the subframe or it could tear away under heavy turning...
If I remember correctly you only need the subframe brace to support the big aftermarket sway bars ie 18-19mm. I got my sway bar off a stock car having the 13mm sway bar that didnt have a subframe brace so I didnt think i needed one....
