- Wed Jun 27, 2007 9:16 pm
#12418
New car, new first post!
Spec list:
Engine:
Stock B18c4 GSR
Y21 transmission with a S80 LSD
4.1Kilo flywheel
Full JDM DC2 Jasma Catback
Carter with a Baffle plate
Suspension
282mm front 240mm rear brakes
K-sport Suspension
Strutt bar front and rear up
Oem swaybars
Rear brake pads Ds2500
Goodridge brake lines
Toyo R888 tires
Exterior:
Amber corners
OEM elec mirrors
Antenna block-off plate
Interior:
Elec windows
OEM lux center console
QSP drift seat
Cusco roll cage
everything else inside is removed from the car
Audio:
just a simple radio for the long trips to the track
This body also had some rust, so me and a buddy fixed that.
After that i started stripping the car down.
Cleaned out all the tar crap and painted the inside flat black.
(I know, its coverd in dust
Coated the underbody and painted the outside/engine bay flatgrey
I got rid of the PS and stole *Miss_Honda*'s non-PS subframe en steering column
it needed a little paint:
Got the steering column and brake lines in:
All the wiring is back in the car so is the dash, i also removed the ignition key:
I also have a Cusco rol cage waiting to be installed
Fixed up the valve cover
ventilation plugs and no PCVbox anymore
Also gave the engine a new timing belt and oli filter.
Fixed a broken weld...
Test fitting the radiator:
Latest picture of the body coming together:
Spec list:
Engine:
Stock B18c4 GSR
4.1Kilo flywheel
Suspension
K-sport Suspension
Oem swaybars
Toyo R888 tires
Exterior:
Amber corners
OEM elec mirrors
Interior:
Elec windows
QSP drift seat
Cusco roll cage
Audio:
