- Thu Aug 06, 2009 10:26 pm
#136240
some of you may remember me posting on here a while back, i had the matt black coupe with the false floor?
well heres a pic from when you last saw it..
then that changed alot over the year...ended up like this...
just need some better brakes behind them wheels ;)
then this happend
so i bought this one...currently swapping all the bits over slowly...
and current pics...
96spec conversion (4x114.3) still fits the racingsparcos
:cool:
and the current spec list...
exterior-
amber corners with USDM sideights
flat ITR Amber side reps
spoon replica mirrors
polyurythane spoon front lip (to be fitted soon)
EK side skirts
USDM/JDM boot reccess with import size plate
USDM Import rear light clusters
"EK9'd" front lights (going to be done soon)
import size front plate with tilting bracket
SirII wind deflectors (fitted again soon)
raised bonnet (will do again soon)
resprayed rocker cover metallic red
integra chrome oil cap
spoon res covers
Datum 1 rear tow hook in anodised red
Handling/performance-
96spec integra hub conversion with lower controle arms, upper controle arms and trailing arms (262mm and 240mm brakes with the 4x114.3 stud pattern)
grooved vented 262mm discs and 240mm unvented discs with yellowstuff ceramic pads all round with dot 5.1 racing brake fluid.
HEL red braided brake hoses with S/S connections
integra ARBs front and rear
DiaYama coilovers
Blox Orange LCA's
ASR subframe brace
Beaks rear lower tie bar
integra 1" master cylinder and servo
VTI upper front strutbrace sprayed metallic red (to be fitted soon)
rear upper strutbrace
rear c-pillar brace
megan racing 4-2-1 heatwrapped manifold with de-cat, DC-sports 2.5" b-pipe with custom cobra backbox angled.
Racingsparco NSII's 15" ( Yoko Parada Spec-2's)(refurbed satin black)
DC-sports induction pipe and added HKS mushroom filter
pipercross breather filter
Interior-
OMP suede 330mm steering wheel and boss
skunk2 heavyweight shift knob
DC-sports single bend short shifter
red stiched handbrake gator and subtle knob (to be fitted soon)
OEM Integra red stiched gear gator
Sparco s/s pedal set (to be fitted soon)
DC2 red Recaros
Recaro matching phone holder
Black snap in OMP Four Point Harnesses
Mac audio 17cm componant speakers upfront with dinamated doors, JL audio 2 way 17cm in fully dynamated parcel shelf , most of boot area coverd in dynamat too
strip'd rear seats and put false floor with harnesses dissapears through.
recarpeted false floor and all boot panels black along with the rear parcel shelth with speaker covers removed
redone doorcards in red alcantara
ripspeed dvd headunit
what i plan to do:
respray front and rear bumpers aswell as bonnet with honda badge smoothed
fit my j's racing bumper scoop
new OEM coupe mats
import centre console
wire tuck engine bay
things that need doing soon
fit spoon front lip
spray all exterior plastics
"EK9" headlights
fit sparco pedals
fit VTI front upper strutbrace
fit the new rear discs
cheers sean
then this happend
and current pics...
:cool:
exterior-
EK side skirts
spoon res covers
DiaYama coilovers
Blox Orange LCA's
ASR subframe brace
rear c-pillar brace
Interior-
DC2 red Recaros
what i plan to do:
new OEM coupe mats
fit spoon front lip
"EK9" headlights
fit sparco pedals
cheers sean
