- Sat Sep 29, 2007 6:19 pm
#24606
BEFORE 5 LUG CONVERSION
AND WHEN I FIRST GOT THE CAR
Turbo d16z6
Back from the wash *about to get smokey*
with the Ls swap turbo floated away
On with the info
93 civic coupe DX
miles on body 152XXX
miles on motor 16XXX
-ENGINE BAY-
Ls-Vtec
b16a Head
CTR Cams
3 angle/Full race P&P
Skunk2 Cam Gears
Skunk2 Cam seal
Skunk2 Strut bar
PasswordJdm CF Intake
PasswordJDM Magnet Oil/Tranny Bolt
GSR Tranny
Exedy Stage 2 Clutch Kit
Exedy Cromoly Flywheel
B18b Block
ITR-
Crank
Pistons
Rods
Bearings
Rings
Oil Pump
Water Pump
Oil Pick up
ITR Manifold
ITR TB
ITR Shift Linkage *Gold*
Toda Timing belt
Knock off 4-2-1 headers
Cosmetic head gasket
Arp Head Stud
Golden eagle Vtec Conversion
NOS Wet Kit 75 Shot
Chipped p06 ECU on Chrome Pro
V-tec 4800
Redline 9500
Launch control 5500
Check Engine Shift light at 9400
MSD Conductor wires 8.5
New dizzy/Cap
Earl's 2 10an Fitting on front of vavle cover for Oil Catch can
Custom Oil Catch can
Alluminum Rad. Bracket
Mishimoto Rad.
Custom Rad. can
New Rad.Hose's
ITR Oem Fuel Pump
New oem Fuel filter
Fuel Gauge
AEM Fuel rail
AEM FPR
Stage 2 axles
-Exterior-
Carbon fiber hood
Sparco hood pin
Mugen style front lip
Amber corner
EK side skirt
50/50 Tail Lights* just installed* will have new pictures up soon
Stanley side markers
Black housing headlights
Mcculloch H.I.D Kit 8000K
-Interior-
Jdm center console
Jdm arm rest
Jdm bronze din
Jdm Clock
Jdm Pole switch
Jdm Climate Control
ITR Cluster *WORKS PERFECT*
Corbeau seats
ITR shiftboot
ITR shift knob
J's Racing Pillar bar
Alpine CDA 9856
-EXHAUST-
Skunk2 B pipe
Skunk2 Test pipe
Tanabe Race Madallion Axle Back
-SUSPENSION-
ITR 5 lug conversion
ITR CW 15" Wheels
Earls SS Brake Line
Hard racing Trailing arm Bushing
Koni Yellow
Omni Power Coilover
Skunk2 LCA
Skunk2 Lug/Studs
Skunk2 Pro Front camber kit
Skunk2 Rear camber kit
- EJ-R/EM2 D.D - F*Ck Thieve$ - PSN I.D:aloCc_cuhx-
Turbo d16z6
On with the info
93 civic coupe DX
-ENGINE BAY-
Ls-Vtec
b16a Head
CTR Cams
Skunk2 Cam Gears
Skunk2 Cam seal
Skunk2 Strut bar
GSR Tranny
B18b Block
ITR-
Crank
Pistons
Rods
Bearings
Rings
Oil Pump
Water Pump
Oil Pick up
ITR Manifold
ITR TB
Toda Timing belt
Arp Head Stud
NOS Wet Kit 75 Shot
V-tec 4800
Redline 9500
Launch control 5500
New dizzy/Cap
Mishimoto Rad.
Custom Rad. can
New Rad.Hose's
ITR Oem Fuel Pump
New oem Fuel filter
Fuel Gauge
AEM Fuel rail
AEM FPR
Stage 2 axles
-Exterior-
Carbon fiber hood
Sparco hood pin
Amber corner
EK side skirt
-Interior-
Jdm center console
Jdm arm rest
Jdm bronze din
Jdm Clock
Jdm Pole switch
Jdm Climate Control
Corbeau seats
ITR shiftboot
ITR shift knob
Alpine CDA 9856
-EXHAUST-
Skunk2 B pipe
Skunk2 Test pipe
-SUSPENSION-
ITR CW 15" Wheels
Earls SS Brake Line
Koni Yellow
Omni Power Coilover
Skunk2 LCA
Skunk2 Lug/Studs
