- Wed Mar 25, 2009 12:24 am
#105507
Hey all im pretty new here but thought id share
tell me what you think
oh and soon to come .... Vtec!! if i can find all the parts that is. see my pr3 build thread http://www.civic-eg.com/viewtopic.php?t=8690&highlight=
heres my 94
- Interior:
blitz turbo timer
avital 4400 alram with remote start and pager
jdm console houses 5 gauges
autometer elec. oil pressure
autometer elec. water temp
autometer elec. fuel pressure
aem uego wide band
autometer boost gauge
new door inserts
new trunk false floor
rear deck under cover
MOMO competition wheel
NRG quick release
NRG short hub
- Exterior:
amber corners
1/2 clear 1/2 red tails
8k hids
Special edition Red Benen tow hooks
- Stereo & Nav:
Kenwood KVT 512
Kenwood Garmin navigation
Audiovox rear view camera
jl 4 channel
alpine typer components and seprates
Mtx amp
Pioneer 12" sub
dynamat front doors
Dynamat Trunk
- Suspension:
Type R 5 lug Swap
PWD JDM 3point strut bar
no name rear upper strut bar
no name c-pillar sturt bar
drop zone struts
skunk2 springs
ASR Special Edition Purple subframe brace
ASR 24mm Sway Bar
ASR Spherical endlinks
ss brake lines
Brembo cross drilled and slotted rotors
Type r calipers
wicked front upper adjustables control arms
wicked lower adjustable in the rear w/ wicked lca's
- Wheels:
rsx wheels with honda "H" emblems
brand new nexxens 205-40-16
- Egine: LS-T 2000 b18b and ls trans
bm ripper shifter
dc sports shift knob
aem fuel rail
aem cam gears
nology spark plug wires
stage 2 clutch masters clutch
fidanza 8lb fly wheel
skunk2 pro series intake mani
hondata inatke mani gasket
avid billet motor mounts
hondata s200/b
walboro 255 fuel pump
Brand new turbonectics t3/t4 62-1 63 trim
full race equal length manifold
3" full race down pipe
fmic
Synapse BOV
tial 44mm Wastegate
10lb tial spring
dsm 450cc injectors
engine damper
gas hood shocks
morso oil pan
ss sending and return oil lines
dss stage 2 axles
typer r crank pulley
new honda timing belt
new honda water pump
new clutch slave on tranny
polished alum. radiator
polished alum. over flow tank
Yowai ss colling plate
PWD JDM gold fender washers all around
Skunk2 Cam seal
mild wire tuck
semi polished block and tranny
Vibrant full 3" tubo back exhaust
3" elec cut out
new tb gaskets
new valve cover gaskets
new plugs
honda tranny fluid
mobil 1 10w30 and K&N filters is all that goes in it
heres my 94
- Interior:
blitz turbo timer
aem uego wide band
new door inserts
NRG quick release
NRG short hub
- Exterior:
amber corners
8k hids
- Stereo & Nav:
Kenwood KVT 512
jl 4 channel
Mtx amp
Pioneer 12" sub
dynamat front doors
Dynamat Trunk
- Suspension:
Type R 5 lug Swap
drop zone struts
skunk2 springs
ASR 24mm Sway Bar
ss brake lines
Type r calipers
- Wheels:
bm ripper shifter
aem fuel rail
aem cam gears
hondata s200/b
fmic
Synapse BOV
tial 44mm Wastegate
10lb tial spring
dsm 450cc injectors
engine damper
gas hood shocks
morso oil pan
dss stage 2 axles
Skunk2 Cam seal
mild wire tuck
3" elec cut out
new tb gaskets
new plugs
honda tranny fluid
"I built it, I drive it, your opinion doesnt matter. It doesn't have to be JDM it just has to be functional."
