- Sat May 09, 2009 4:01 pm
#115784
Today i decided to build the mounts for the brake fluid reservoirs, they are not so small so gave me some trouble to find a good spot. after some measuring and lots of trial fittings, I decided to mount them under the former vent in the top center of the dash, this way they are easily accessible and easily covered and out of sight.
Problem was that the heater didn't leave much room to work with, so decided to mount a bracket onto the heater, which itself is a solid steel cased unit, so this was good:
I had disassembled the heater unit in order to safely weld the bracket onto it, thereafter re-assembled the heater core:
Mounted the heater onto the brackets that we had welded in a while ago:
I had measured out the distances so that the reservoirs would basically be about 2 mm over the welded in crossbrace, luckily this came together nicely:
Now fitted the dash over it:
And nicely covered up:
