DC4rob wrote:
Gorveatt wrote:
Graham wrote:4wd eg wtf!!!!!!! :o
you didn't know they were made factory? They were only available in as sedans though
they also made 4wd tegs too
WHAT WHAT WHAT!!!!!!! :shock:
By asianrob
#81772
yup http://english.auto.vl.ru/catalog/11804/
By ee8
#81773
4 door only i assume?
Don't care, WANT!!111one elevnty one !!!!1
By lopez286
#81986 men u guys do anything ha. :cheers:
Read that awesome engine displacment!!! 1590 ccs... Its a ZC motor.
By hontec
#82007
lopez286 wrote:men u guys do anything ha. :cheers:
we try! :D
By Classiccarsrule85
#83010
Lol if you read down further it tells you its a ZC motor with a whopping 120hp at 6500 rpm....its not bad but all you probaly need to do is take a Honda Passports B20 motor and trans n drop it in then its a B series in a teggy
By asianrob
#83051
yup
By ee8
#87249 Finished cleaning the engine I bought for fitment. The one in the earlier pictures is a C35 and has a different layout then a C30 or C32. For instance it has a balance shaft and a different waterpump setup.
Since I needed a similar block to a C30 but I didn't want to buy an NSx engine up front since there is always a slight chance that a project like this fails, I sourced an old honda legend C27 engine, it is an SOHC originally but the engine itself is vitually identical to a C30. the NSX C30 is derived from this C27 and the layout and transmission bolt pattern are identical. Also many NSX parts fit directly to the C27.
The C27 comes from an old 1989 Rover 827 Sterling which was fitted with this honda V6
(The C25 and C27 legend engines are alike except for the piston diameter.) I've also toyed with the idea of using this lower engine block and re-sleeving it with Darton MID sleeves upto 93mm and using the stock 75mm stroke compared to the nsx stock 78mm stroke, which in turn gives me higher rpm and a 3,1L high rpm engine...but after measuring, I came up with a little problem in deck height and all of this is do-able but will require so much engineering that buying a stock nsx engine will be better in the end...
for now I've cleaned the C27 and mounted a new oem nsx waterpump, a new oem nsx oil pump, a new oem nsx timing cover and a new oem nsx oil pan..
A new alternator bracket is on it's way and the front engine mount bolts to this bracket. When it is in place, I am going to put the whole setup together with the adapterplate and then I can start putting it in it's final position in the car and fab up the engine/transmission mounts/brackets.
pictures....
By asianrob
#87309 thats a sexy looking block!
one day you all should get a 1uzfe from a LS400 or Soarer/Sc400 and drop one in an integra one day lol a V8 integra would be nice :D
By spiritR
#87323 should put a toilet as a driver seat cuz driving that thing WILL make you shit your yourself :thumb:
By hontec
#87840 Received the Alternator/front motormount bracket today, testfitted and mounted it together with a new NSX alternator and a cleaned bracket.
Also received the adapter plate machined by Kennedy Egineered Products!! damn the plate and flywheel are truly a work of art! Compliments to them. Visited them in person in Palmdale CA when I was over there in November for my work, and was really impressed by what they make/do......naturally ordered the plate etc but was happy I went there, it was never done before apparently...
So all went well and received it today.... will testfit it tomorrow and begin fabrication of the side motormounts..
Pictures for now..
spiritR wrote:should put a toilet as a driver seat cuz driving that thing WILL make you shit your yourself :thumb:
HAHAHA! :lol: :lol: :lol:
By hontec
#87886 Started fitting the adapterplate, first not to damage anything, I retapped all the threads:
Then inserted the alignment pegs:
And then the plate went over it like a glove:
Fitted the flywheel roughly, since there is no crank to mount it to:
And just to try and fit the plate to a new nsx flywheel side transmission casing, fits like a glove, here you can see the plate is machined for the nsx since aligning it with the legend block gives a few minor differences and on the transmission housing, it is a solid match...
