- Mon Oct 04, 2010 9:17 pm
#216805
Here a trouble shoot procedure from a fellow D16z6 for idle issue owner..
When u start the car cold generally it goes to 1800 rpms and gradually comes down to about 850 right below the 1000 mark.
If your idle dips up and down after warm up, check the coolant system for air like the guy above mentioned.. with the engince already warm use a 12mm wrench to loosen the bleeder at the top radiator hose. if all air is out coolant should shoot straight up in a steady stream or pour right over the bleeder screw. if air is in the system u will see steam come out followed by a few bursts of coolant until it's a steady coolant coming out.
That takes care of that.
Now if you Idle tends to stay anywhere above 1500+ rpms. it's caused by a few things,
!. Stuck throttle cable, but this is no typial doesnt happen often...
2. Fast Idle Valve attached to the bottom your Throttle body where one small coolant hose connects to it.
3. Idle air Cotrol Valcve Needs replacing or a good cleaning. That's located behind the Intake manifold. air intake cleaner usually fixes this part.
Part #2 if it's not functioning properly then it needs to get replaced completely. It's a $50 new at the dealer..
Hope this helps u out more.. and good luck any more questions feel free to ask that's why we are here!!
