JDMD15B wrote:what about the y8 mang!!!!!!!!!!!!!!!!!???????
There's no mistaking the y8 for any other manifold...
Notice the big fat plenum compared to the skinny D16z6 and D16b7 plenum.
99-00 y8's have cold start assist, which will need to be blocked off when used on earlier D series.
The 4 tiny holes on the mounting surface, above each runner, must be filled/welded/blocked and the extra vacuum line on top of the flange can be capped off.
Also note the webbing between the runners.
A D16y5 intake manifold looks similar to the y8 intake manifold, but it has an EGR valve, which is NOT what you want to use.
Also look for a manual y8 intake manifold, as the automatics have the IACV built into the throttle body.
i allways kinda wondered, it was in the back of my mind from a while ago when i put that one on my hatch when it had a mini me in it, and this thread reminded me of it...
