z6 head:
z1 dizzy will fit
y8 head:
slightly higher compression
will need to buy obd1 dizzy from d15b7/b8 to fit
That's the only major difference, unless you will also be replacing the intake manifolds. then...
z6 IM:
obd1 = same sensors
slightly better top end flow
y8 im:
99-00 has cold start assist, additional holes to plug vs 96-98
IAT sensor will need to be relocated
must be from a manual y8
injectors will not fit obd1 plugs
slightly better mid rpm flow
the VX IM is pretty small/restrictive, may want to consider upgrading
