- Tue Jan 12, 2010 10:21 pm
#167961
is your car running or no. if it wont start i would say pump or relay.
- Tue Jan 12, 2010 10:55 pm
#167968
it barely wants to start...like i cranks up the cuts right off and after few times of this if i can catch the gas pedal at the right time it will stay running....but runs ruff....i also got a code 4 which is crank shaft position sensor...
- Wed Jan 13, 2010 12:45 am
#167986
crank shaft position sensor is in the Distributor.
See if you can borrow a distributor from a friend and try it on your engine.
Remember to unhook the battery for 10-15 mins to clear the codes. Or there's the ECU fuse you can pull, but I forget which one/color it is. I think it's red 10A in the underhood fuse box
- Wed Jan 13, 2010 3:12 pm
#168112
Just disconnect the ecu just take the 3 pugs out and put them back in it will re set the ecu I went thure 6 fucking tempeture sensers I kept pulling out the fuse and that shit never re set I disconnected the ecu and bam no more code 6
