- Fri May 28, 2010 11:28 pm
#197539
hey, so my original setup was a d16y7 with a b7 intake manifold and y7 throttle body, iac on mani blocked off, no evap, idled perfect and pulled thru the powerband
swapped to a z6 mani, same block off setup, ob1 h22 throttle body, idled perfect pulled thru the power band, but at high idle and at 1500 rpm will bounce slowly like a step 2 launch control lol, and under engine braking will spudder and jerk between 2000 and 1500
new setup, b18b1, p2e virgin ecu, stock 97 cx harness, crank sensor bypass mod, obd2 d series injectors, repinned 3 wire mani mounted iac for 2 wire, b series throttle body that came with the motor, car the swap came out of ran perfect, no issues
same studder issue, have tryed new ecu and different injectors, any ideas peeps, drives awesome just an enoying problem
EZ MotorSports
Revin... any guesses on the orgin of the nickname
got me thinking, im gonna run out to the shop and check a couple things, i left the purge valve on the mani not plugged into anything, could be leaking when the throttle opens and vacuum is lost, sounds like my motors have the same problems two different causes, perfect idle, bounces at 1500 when throttle is applied, but straightens out at 1600, shutters between 2000 and 1500 under deceleration and engine breaking
