port & polish
anyone had this done.
what will i gain hp wise roughly.
only got cat-back exhaust an air filter
oh yeah on a D16z6
oh yeah on a D16z6
VerLee24 wrote:first of all, im hoping that you wouldn't hack at it with a dremel yourself but pay a shop to do the work.. in this case.
HP gains aren't much if you just leave it at PnP.
the name of the game is air flow. the more air you can get in and out the more power you can make.
compaired to a straw, would you rather suck through a bubble tea straw or a coffee straw?
but just a PnP? thats like sucking through... a coffee straw that bulges to a fat straw in the middle and then back to a coffee straw... kind of pointless if you dont have it at both ends eh?
PnP, header, exhaust, cam, oversized valves, ITBs... oh wait.. why would you be going n/a with a d16z6 anyways...
save your money and boost it.
VerLee24 wrote:what is your definition of beastly? granted if anything is 'done right' you can have a 700whp sohc bisimoto style. however, most of us dont have that kind of budget. Of course if you have enough money anything is possible.
n/a
http://jgenginedynamics.com/_dyno%20pdf ... %20pic.pdf
226 HP on 100octane with a 5000$ motor.
boost
http://img244.imageshack.us/i/image011wq4.jpg/
234HP on 93 octane with a stock d16y8 and a 2000$ turbo kit.
dro, what does this have to do with a port job anyways?
Randull wrote:Hey guys,
I kind of wanted to chime in slightly because after talking to a few companies yesterday at Spocom there are some factors that must be taken into consideration regarding a PnP
The first thing is that it will help but it must be done appropriately. The polishing part is where things can get weird. I have seen quite a few people do these high finish polishes in there head but in fact it is doing nothing but hurting the potential ability to make power. In fact, that type of polish keeps fuel from properly atomizing and mixing and allows it to flow on the hug the surfaces rather than to mix with air.
In actuality, a rougher finish will create turbulence on molecules trying to hug the surfaces and bounce them into air molecules giving you a better mixture. So in actuality, a PnP will help out but it has to be done right or it may end up being more detrimental
-randy
Randull wrote:Hey guys,Polishing is done only on the exhaust side of things, due to what you stated. way to do your homework lol.
-randy
