- Sat Jul 03, 2010 7:31 pm
#203076
I have a situation where I can't start the engine. Here is the story:
Leaving work, start the car and everything is fine. Gas is near E but heading to the gas station anyways so no problem.
At a stop light and all a sudden, engine cuts off. Tried to start her again, and all i hear is the crank. Seems like no spark is going to the engine for it to turn over. At this time, I'm thinking to myself:
1. Either gas is low which the fuel pump isn't getting anything to the injectors. No problem, call my bro to get some gas while I sit there in the traffic. And brother finally came and I top it off with 2 gallon of gas.
All sounds fine, and I can hear the fuel pump when I turn the key to "On".
Then my brother unplug Cylinder #3 spark plug out and oil is covering the spark plug and the wires. No problem. Tow it home and switch out some new plugs and sparks.
Switched it all out, have gas in the tank. Change the oil and Cap + rotor, wires and tried to start her up.
No Dice!!! Getting me pissed off. I smell gas coming out from the injectors. And i see small amount of gas coming out from the bottom rail where the injector are plugged into the rail.
So, is my injectors clogged? Or is it my distributor shot?
Please help as I am noticing my power steering pump is overflowing due to my cranking of the car.
