- Mon Sep 13, 2010 5:54 am
#213359
ok well i am new to this sight. i have a question for ya i just got my 5th civic 10th honda. i just changed the motor and it ran before it just spun a rod bearing before i got it so went from d15b2 w/y8 head to just a d15b7 and now its not getting spark or fuel and ive checked the wiring like 10 times. wen i first tryed to start it it was getting fuel and i know theres gas in it and now nothing. and with the spark i was think it was the dizzy it has a z6 dizzy in it cause i plan on switching the heads shortly just want it running now. so if anyone has any ideas it would be great and thanks in advance
- Mon Sep 13, 2010 6:06 am
#213361
you cant run a vtec dizzy on a non vtec motor.
it will only bolt up to one bolt, meaning that you probably have it off timing by who knows how much.
i say find a d15b7 dizzy(nonvtec) and see if that was the problem.
and what harness are you using?
since you said you had a y8 head on there im guessing you had an obd2 (96-2000) civic harness which is completely different from the obd1 and this will also make the car not run.
check that out and let me know what you have come up with.
good luck
that but if anyone has any idea about wat it could be.ill try alomst anything to get it running again and thanks jdm at least i know im not the only one
