- Mon Sep 20, 2010 2:52 pm
#214595
part numbers added
these are numbers you can go to your local dealer and order them
i went the cheper way and i got ebay stuff but these are official part numbers
this is a complete list of things you will need to rebuild a 92-95 jdm spec d15b
the only thing that is unavailible for this motor is the crank and pistons
if you speak japanese you could probably get some autoparts store in japan to ship here
head portion
all seals are the same as d16z6
cam seal,dizzy o ring vlave stem seals , head gasket , valve cover all d16z6
bottom end
piston rings
d16y8 or d15z1 piston rings
main bearings
d15b7
rod bearings
d16z6
water pump and timing belt
d15z51 (vx model)
spark plugs
d16z6
oil filter
any d series oil filter will work
rear main seal
any d series
oil pump
any d series oil pump from 92 to 95 so any d15b and d16z6
rods
same as d16z6
part numbers :
valve stem seals: intake-12210-PZ1-004
exhaust-12211-PZ1-004
rods:13210-PM6-000
rod bearings can not be ordered from the dealer !
they are on permanant backorder
so i ordered clevite bearings stock size
here is there part number
rod bearings from clevite :CB1461P
and i also ordered main bearings from them
here is that part number
main bearings from clevite : MS1806AL
thrust washer from honda: 13014-PD1-S20
rear main seal:91214-PLE-003
oil pump:15100-P06-A02
water pump:19200-P08-004
timing belt:14400-P08-004
piston rings:13011-P07-004
crank and pistons dont even try to find them haha
if you do find a company that makes or imports them into the us tell me haha
this is more for personal refrence but decided to share with the class
sticky maybe?
head portion
bottom end
piston rings
main bearings
d15b7
rod bearings
d16z6
d15z51 (vx model)
spark plugs
d16z6
oil filter
rear main seal
any d series
oil pump
rods
same as d16z6
part numbers :
rods:13210-PM6-000
sticky maybe?
