- Fri Sep 24, 2010 1:29 am
#215147
anybody know why this is happening??? no rough edges cleaned it to a shine and still stick
Also, what part of Cincy you from?
"So if you're god, does that mean you know what i'm going to do before I do it?" "Yes" "But what if I do something different?" "then I don't know that."
dont touch that screw at all. it was set at the factory and painted as you can see to never be or get or become adjusted. that will only throw your TPS off. if it's sticking check the cable itself. while mounted on the Manifold with the cable on open the the throttle by hand and see if the cable has alot of SLACK as if it could come off hang off the side a bit. if it does tighten up the cable but just leave a lil bit of slack abd spray the heck out the spring that is there with wd-40 or some good grease..
