By 7one3
#217944 sup guys love the fourm well today on my way home my 95 eg decides to just die while i was rolling the oil light and battery light came on but oil looks good and battery tested fine i have no idea what it could be help please
By That One Dude
#217963 Well, when the engine shuts off, the oil pump stops pumping and the alternator stops turning and generating power. The oil light comes on because the pump stopped pumping, and the battery light comes on because the alternator stopped generating power.
Without any other info, there's nothing I/we can do to help you.
Do you have a CEL? Are your engine/tranny/battery grounds in good shape? Are they tight? Have you done any modifications recently? Have you done any heavy maintenance lately?
By 7one3
#217970 I haven't done.anything the car is bone stock
By MG6
#217973 does it start when you crank it? More detail please.
By 7one3
#217990 It just rolls over like it wants too but it won't start
By 7one3
#218049 Ok will do thanks
By 7one3
#218122 Some one told me it might be my head gasket is yhis true ????
By MG6
#218146 headgasket? I don't believe so, but your best thing to do is search on this forum and read up about headgasket. This way, you will know what to look for.
By 7one3
#218169 I tried a cap and rotor last night and nothing I'm gonna try a new dizzy tonight
By ghskid06
#218179 well wait, before you do that make sure you arent getting spark. If your getting spark then its probably a fuel issue, which is possible also although usually those problems come up after the car has been turned off and then wont start again, its still not worth buying a new dizzy if you dont have too. But for future reference there are endless possibilities as to what happened to your car based on the info you gave us. Your timing belt could have snapped for all we know. But that doesnt mean that i think thats your problem.
By Eg6H2D
#218228 It's the Dizzy. same thing happened to me on the highway..
By 7one3
#218264 does it matter if the dizzy is vtec and my car isnt will it bolt up
By Eg6H2D
#218365 the mounting points on thedizzy for a z6 are unique. if you have a d15b7 dzzy open it and take the Module off that and slap in the z6 dizzy if it's identical that should fix the problem.
By 7one3
#218536 Tried cap and rotor and nothing but I am getting fuel
