d15b7-d15b8
D15B7
* Found in:
o 1992-1995 Honda Civic CX (Canadian model)
o 1992-1995 Honda Civic DX/LX
o 1993-1995 Honda Civic del Sol S
o 1992-1995 Honda Civic LSi Coupe (European Market)
+ Displacement : 1,493 cc (91.1 cu in)
+ Bore and Stroke : 75 × 84.5 mm (3.0 × 3.33 in)
+ Compression : 9.2:1
+ Power : 102 hp (76.1 kW, 109 ps) @ 5900 rpm (102 hp @ 5900 rpm in U.S.)
+ Torque : 98 ft·lbf (13.5 kg/m, 133 Nm) @ 5000 rpm
+ Valvetrain : SOHC (4 valves per cylinder)
+ Cam Gear: 38 Tooth
+ Piston Code : PM3
+ Fuel Control : OBD-1 MPFI
+ ECU Code: P06
+ Head code: PM 9-6
D15B8
* Found in:
o 1992-1995 Honda Civic CX (U.S. model)
+ Compression : 9.1:1
+ Power : 70 hp (52.2 kW, 71.0 ps) @ 4500 rpm
+ Torque : 83 ft·lbf (11.5 kg/m, 113 Nm) @ 2800 rpm
+ Valvetrain : SOHC (2 valves per cylinder)
+ Fuel Control : OBD-1 MPFI.
i have both motors the d15b7 is in the car but its seized up i bought the car this way so i have no idea how it got that way
my question is will the transmissions swap are they the same or whats the differences
throttle body on the b7 is way larger than the b8 question is will the whole manifold swap with out issues
im trying to get more power out of the working b8 untill i can afford something bigger
* Found in:
+ Piston Code : PM3
+ ECU Code: P06
+ Head code: PM 9-6
D15B8
* Found in:
