- Sun Jan 30, 2011 6:43 am
#236149
what is a good price to pay for a y8 head used?
- Sun Jan 30, 2011 8:54 pm
#236182
if your buyin new might as well go with arp i think there like 150 bucks
- Mon Jan 31, 2011 12:37 am
#236229
$100 assuming it came with a valve cover, cam gear & vtec solenoid and there's nothing wrong w/ the head
- Mon Jan 31, 2011 3:27 am
#236244
ok thanks guy
- Tue Feb 01, 2011 9:30 pm
#236522
what all should i do to the head before in stalling it?
- Tue Feb 01, 2011 9:58 pm
#236529
I'd check that the surface isn't warped and that the valves don't have any damage. You could get it hot tanked if it's really dirty or has been sitting out w/o a valve cover.
Or are talking cam & valve train upgrade and some port & polish?
- Tue Feb 01, 2011 11:04 pm
#236540
do you know any upgrade that r cheap and easy to do? and would what well with a stock d15b7 usdm bottom end
- Thu Feb 03, 2011 6:59 pm
#236879
bump
- Thu Feb 03, 2011 7:37 pm
#236894
well, I wouldn't shave the head, your compression ration is already going to be somewhat high and you probably want to use pump gas in this car.
Short of cam & valve train upgrade and some port & polish... there's not much in the cheap category that you can do.
You could do some research and learn to port & polish yourself but you still need the tools and if not done properly it can hurt performance.
I'd bolt the head on and put the $/effort elsewhere like suspension, wheels/tires/ex or si tranny etc.
The tranny will make a big difference in acceleration
- Thu Feb 03, 2011 7:51 pm
#236897
ok sweetness
