- Mon Jan 31, 2011 3:13 am
#236243
iv been hanging out with alot of autox dudes in my town and they all love the vw 2.0 cause you can build 1.9 strokers out of them and get good power
i said that hondas you can do the same thing and they all laughed at me and just shook thier head
so i got home and started playing with zealaoutoworks compression calc and came up with a sweet motor build
i know you can get higher compression builds with way less work but i think this one would be more reliable with less tuning
here it goes
tell me what u guys think
d16z6 block
d16z6 rods
d16y8 head
d15b7 pistons
arp rod bolts and head bolts
z6 head gasket
you say the b7 pistons will stick out of the block?
they will
untill you mill them down .028
combined with milling the head .020 this will give a 11.98 to 1 compression wich seems high yes but i think it will be reliable bc of the fact that the b7 pistons are basically perfect for high compression they are perfectly flat and milling them .028 wont do much to affect the valve reliefs
also timing wont be hard just by an adjustable cam gear and set timing 4 degrees past tdc
also was thinking about high compresion valves that would take the head cc down to 31cc instead of 32.80
soo tell me what you all think
i could do all this for under 500 bucks also
here it goes
d16z6 block
d16z6 rods
d16y8 head
d15b7 pistons
z6 head gasket
they will
my build> blue bandit-sold=[
http://civic-eg.com/viewtopic.php?p=203107#203107
taco build!
http://civic-eg.com/viewtopic.php?t=17613
taco build!
