- Tue May 17, 2011 12:48 am
#255520
d15b7/z6 mini me
Head was resurfaced and valve job.
All new gaskets and seals when head was installed.
Reused b7 head bolts, torqued correctly.
Timing seems to be a little off.
Had idle problem but now idles well.
Puffs out, what looks to me like, white smoke.
500 miles driven = 1QT of Oil missing.
Coolant stays full w/coolant still in overflow catch.
Did the following so far;
Looked at tops of pistons by shining a flashlight in the spark plug hole.
-Car had sat overnight
No visible oil on tops of pistons. Spark plugs look clean as well.
No oil leaks.
Compression Test Numbers:
Dizzy 260 240 240 270 Timing Belt
Compression seems high and it's still burning oil? I mean, the oil is going somewhere and it's still smoking.
No oil leaks.
