D16Z6 cooling problem?!?!?!!
1st of all fan wasnt coming on so i jumped the thermo switch to see if the fan was burnt out-fan came on.
Replaced the Thermo switch and thought since i was doing that i might as well do the other temp sensors and a new thermostat(yes the correct way).
Got everything back together, topped off the coolant and started it; everything sounded and looked ok, no leaks, sounds, etc.
Go for a drive and the car starts getting hot on the freeway, so i pull off turn the heat on high hott and its cools to about halfway. Get back home and notice ONLY the top radiator hose is hott and the bottom completely cold!
Just replaced the thermostat too! So my next thought is the water pump.
I squeeze the hose when the car is running and not really any pressure.
So i replace the water pump, fill it back up with coolant, start the car let it run for about 5min. It warms up ALOT faster than ever before so i gt out and check the lower radiator hose-STILL COLD.
Still no leaks, new water pump, thermostat, thermo switch, ect, squeeze hoses and it DOES have pressure but NO flow. Also i dont have a bleed screw by the top radiator hose.
I DONT GET IT.
I DONT GET IT.
