- Wed Oct 19, 2011 7:10 am
#278263
So I bought my ej1 in January, and it has had code 14 since then. I have changed out the iacv 4 times, cleaned out the fitv, and changed the fitv. I have ran a straight wire from the ecu to the sensor and nothing same idle problem, and I can't drive slow with it cuz I bounces the idle around. The only thing that I can think of is changing out the ecu. Any other suggestions of what I might have missed? Oh I also changed the pcv valve, and bled the coolant system, and changed the coolant temp sensor.
Any ideas? I really need to get this fixed to smog it.
